Scott (NE)
10-21-1999 08:21:44
I�ve been looking for a tractor for our 20 acres for mowing, driveway maintenance, garden prep, building some fence, as well as anything else I can think of a reason to use it for. I�ve seen plenty of N�s, but this is the first NAA I�ve run across. It�s a couple hours away but sounds promising enough to make the trip to check it out this Saturday. It's supposed to be a '53, used year-round, starts and runs well, new tires, etc., etc. The current owner is 65ish, bought it about a year and a half ago when his neighbor retired, and used it to put in some fence and do some grading. Says he's run out of jobs to justify keeping it and is selling his implements as well (loader, back blade, dirt scoop, post hole auger, plow, sickle mower, tire chains). Beyond the usual (running it, checking fluids and hydraulics, compression), is there anything specific to the NAA that I should be looking for? Typical places for cracks in the manifold or block, anything that�s often a chronic problem, etc.? Since it's been used with a loader, is there a quick and easy way to check the front end wear? Lots of questions, I know, but I really did go through the archives first!
