2N sticky brake
Greg in mi
10-18-1999 17:47:10
the left brake stays down when I press it. it comes back up by hand, and stays up until I press it again.
llamas
10-19-1999 04:02:50
 Re: 2N sticky brake in reply to Greg in mi, 10-18-1999 17:47:10
Before you tear it all apart, try this -
The end of the brake shaft, which is also the clutch pedal pivot, works in a hole in the flange of the axle trumpet. This hole is supposed to have a bronze bushing pressed into it. This pivot is inaccessible (it hides behind the clutch pedal pivot) and is well-known for filling with packed grime. Slide the clutch pedla sideways after loosening the brake pedal, and get this cleaned out. Carb cleaner, then compressed air. Then oil liberally.
If that don't free it, then, as said, you most likely have weak or broken brake shoe return springs.
llater,
llamas
dave
10-18-1999 19:43:59
sounds like one of the 3 springs in the left brake housing might have broken..need to remove wheel and take off drum to get to these(a pain in the the butt)...make sure nothing is binding first, spray alot of WD40 all over the place along the pedal path..
dave
TimK
10-19-1999 12:23:41
 Re: Re: 2N sticky brake in reply to dave, 10-18-1999 19:43:59
If you wind up digging into the brakes, take a look inside the cylinder that functions to expand the brake shoes. There is a wedged shaped "device" in there which can be accidently turned the wrong way causing binding every time you step on the brake. I know, because I had a sticky pedal when I got my 2n and that was one of the reasons for the sticking. My 2 cents.
