Electronic Ignition Kits????
Truck
10-18-1999 16:13:48
Does anyone remember who it was besides Genesee products that sold the electronic ignition kits here at YT? Or was the ad for $ 59.95 kits a dream I had? Also is there a front mount kit in the works anywhere? I have some helpers who just love to leave the ignition on when they can't figure out how to start a 2N... And I am getting very tired of buying point sets and coils..... Thanks!
David (La)
10-19-1999 07:46:59
 Re: Electronic Ignition Kits???? in reply to Truck, 10-18-1999 16:13:48
My sidemount is happy with the 1978 Toyota Corolla electronic ignition and it starts at the first bump of the starter. I found the solution in the links off of BG's web page.
EricG.NH
10-18-1999 17:35:00
There's also the 6V or 12V question. They do advertise a 6V version, but be careful. It's not guaranteed to work on less than 4.5V. This is just a guess, but most electronic ignitions are powered by a small Motorola chip, designed specifically for this application, an ASIC. Application Specific Intergrated Circuit. It's designed to operate on a 12V system, but over a large range of voltages. Using it "as is" on a 6V is very limiting. The 4.5V limitation is just not practical, IMHO. I looked at this and felt the simpliest solution involved using a voltage doubler to source the IC. My 2 cents is leave a 6V ignition as is, at least until a better electronic one comes out. However once the leap is made to 12V, stand back! All sorts of possibilites open up then.
Eric
P.S. Pertronix makes them too. Not sure if it's the same as Genesee.
Rob
10-18-1999 16:54:41
Denny's Carb Shop Tractor Products 937-368-2304
Sells Pertronix kits for $59
Bill
10-19-1999 08:23:35
 Re: Re: Electronic Ignition Kits???? in reply to Rob, 10-18-1999 16:54:41
I would NOT go to Denny's Crap Shop!!!!
He will take your money then he will rip you off by selling overpriced junk.
Truck.. Thanks ! I knew I saw it here! NT
10-18-1999 20:18:33
