Order Ford 8N Parts Online
49 8n oil in coolant
ken mn.
10-18-1999 15:53:02
would appreciate any ideas on source of oil entering cooling system. thanks
Gary (UT)
10-19-1999 09:31:53
 Re: 49 8n oil in coolant in reply to ken mn., 10-18-1999 15:53:02
Ken,
What looks like oil is probably exhaust particles in your coolant. After rebuilding my 2N engine I realized the following, If you have a cracked block you would also have water in the crankcase. If it is oil and you have no water in the crankcase, your valve guide seals are shot and/or your rings are shot. Also, the head gasket is bad and allows oil AND exhaust to be forced past the gasket and into the cooling system. My rebuild included milling my cylinder head and installing a new head gasket. This solved my problem. Good luck!
Gary
Gary (OR)
10-19-1999 07:27:41
I had the same problem this spring. I changed the head gasket (advice from this board) and the problem went away. It may not be your problem but the gasket is cheap and fairly easy to change.
Gary (OR)
EricG.NH
10-18-1999 17:36:30
Cracked head. Cracked block. Head gasket.
Eric
