Order Ford 8N Parts Online
8N Hydraulic lift
Hendo (OR)
03-03-2000 06:47:17
I am getting only about a 50% lift on my 8N system, what is the cause of this?
Nolan
03-03-2000 07:45:47
 Re: 8N Hydraulic lift in reply to Hendo (OR), 03-03-2000 06:47:17
By 50% I take it you mean height, right? If so, the usuall cause is wear on the pin. It causes the linkage to essentially see a false full up. You can adjust for this somewhat by loosening the four quadrant bolts and shifting the unit rearward. But the proper and thorough fix is to remove the lift cover, and do an R&R on the components.
Hilltopper
03-03-2000 07:51:27
 Re: Re: 8N Hydraulic lift in reply to Nolan, 03-03-2000 07:45:47
My lift is weak but lifts ok for what I do. My question, is when the draft control lever is down the three point will not lift up unless the draft control lever is held down. Is there an external adjustment for this? Also be sure to check your gear oil level.
