53 jublee
Mike Mundy
10-16-1999 16:16:10
I purchased a 1953 ford jublee and it has on ezch side of the front a decal that says Model 640. What does this mean and is it original?
Jay Andrews TX
10-16-1999 21:50:38
 Re: 53 jublee in reply to Mike Mundy, 10-16-1999 16:16:10
Check the face of the rear axles, if they have a nut in the center it is a jubilee or NAA [One of the same]. They look the same as the late 8N. If the axle face is smoothe or has no nut it is likely to be a 640.....Jay
You need....bg
10-16-1999 18:56:39
...to go to Dan's Vintage Ford Tractor Resource Page and check out the information. You may have a 640 that someone calls a Jubilee. Or you may have Jubilee with 640 stickers on it. Dan's site has pictures and numbers that should clear it up for you.
RICK
10-16-1999 17:17:03
First find the serial number, then you can determine if you have a Jub emblem on a 640, or decals to update a Jub, or something entirely different than either.
