Air, Fuel, Fire and it dont start!
Tom WY
10-14-1999 20:45:57
What gives?!
I assume I'm getting air, I have gasoline running from the plug in the bottom of the carb, Spark at the plugs. What the heck am I missing??
I was driving the '47 2N last Sunday, probably 4 miles, it kinda lost some power (maybe). I stopped to shift down, let out the clutch and it died. Luckily 30' from my garage door. I had been about 2 miles from home. I was reading here a few days ago about ways to test the coil by checking the voltage with the points open then closed but I'm too dumb to know what the results mean. I have tested this 4 alternating times with these results...
points open; 1.23v, 6.11v, 6.10v, 6.12v
points closed; 5.55v, 1.11v, .75v, 5.6v
Supposed to snow tonight. Hope not enough to blade!
Phil (NJ)
10-15-1999 07:28:52
 Re: Air, Fuel, Fire and it dont start! in reply to Tom WY, 10-14-1999 20:45:57
Tom, I assume you have front mount Dist. The readings should be Bat 6.2V when the points are Open, and about 2 to 3 Volts when closed. The coil is about .75 ohms and 3 amps of current will result in (.75 X 3)= 2.25 volts.
Your readings of .75V and 1.11V are "very Low" and indicate that you only have about 1 Amp of current in the circuit. (.75 /.75 = 1)
The only components that should have a significant( > .5 v) voltage drop are the coil and Ballast
resistor, and the total sum (coil voltage + Ballast resistor voltage) should be about equal to the battery (6.2v)
Your readings would indicate that additional resistance is in your circuit. a) Bad Ballast Resistor b) Bad ignition Switch c) Bad Battery Connections
You can simply measure across each of the components looking for the missing/bad voltage drop ie.)If the coil measures .75V points closed, you are looking for (6.2v - .75v =) 5.7v
Hope this helps,
870
10-15-1999 05:38:36
try cranking after spraying a little starting fluid. if that does not work check position of timing. could be a timing gear of timing chain broke or slipped.
Dave (Mars,PA)
10-15-1999 04:24:32
This shouldn't be too difficult to diagnose. Spark+fuel+air+proper timing=run. It's a decent bet the timing is okay. Let's assume it is. Your assumption that you're getting air is also reasonable. You say you have spark. Strong spark? Again, I'm assuming so. That leaves fuel. Fuel at the carb doesn't necessarily mean fuel in the chamber. There's an easy way to test this. Remove the air intake tube and try spraying some starter fluid in there while cranking. If it starts, then you know the problem is internal to the carb. I'd guess a stuck float, leaky float, or clogged jet. If using starting fluid doesn't even produce a pop, then I'd move on to diagnosing the ignition. But I always like to eliminate the simple things first.
Jim
10-15-1999 03:58:26
I suspect ignition problems. Do you have a resistor in line with your coil, if not get a coil and resister. If so try jumping a wire from your battery side of the resister direct to the hot side of you battery, if that works, the switch is bad. You have checked a plug wire by now turning the engine over to see if there is fire on a regular basis? If not, you could have a bad condensor or broken spring on your point set. If the carb is stopped up, you should be able to get the tractor to run when it is choked. What do your plugs look like, if they are very clean and dry, you have a carb problem. If wet or sooted out, an ign problem.
Sam (Mo.)
10-14-1999 23:02:05
You have gas running from the bottom of the carburetor, but maybe it's not getting through the carb. jet and into the engine. A plugged jet from dirt or rust in the fuel is pretty common and something to check.
Bruce
10-14-1999 21:52:05
Compression mabe?? Dit it hole a piston or suck a valve?? Crank it over with your hand over the exaust pipe, it should not suck at your hand. BE SAFE!!
