2N OVH
Don
10-11-1999 13:51:41
I'm going to do a minor OVH on a 2N.I've pulled the eng down,it has been OVH before.
It has the thick wall sleeves & .010 rod bearings.
Sleeves appear to be "ok"some minor pitting.
Pistons "ok",rings worn especially oil rings.
Do you think I can get by, by replacing the rings
& rod bearings??Tractor isn't going to be used
for work,just occasionaly pulling a small trailer
around loaded with small tools(shovles,rakes etc)
Appreciate any help,THANKS
ZANE
10-11-1999 16:41:37
 Re: 2N OVH in reply to Don, 10-11-1999 13:51:41
I would replace the rings and the bearings and give the valves a gool look over and put her back together if that is all you plan to do with it.
TimK
10-12-1999 07:33:02
 Re: Re: 2N OVH in reply to ZANE, 10-11-1999 16:41:37
Unless he's committed to just a ring job, he really needs to mike the bores for wear and taper to know for sure if he can get by with just a re-ring job. And if he hasn't had any gauge training, leave the micrometer work to a pro. I would also check the pistons closely for cracks, especially along the lands and check/renew if necessary the rod bushings (don't use the old keepers ). My 2 cents.
