Loader removal
lh
10-10-1999 18:08:07
I have a 19-22 dearborn loader with the front mounted pump.I could use a little advice on the procedure for removing the loader, and should you do anything special to the loader for storage?
Thanks in advance.
E. Allison
10-12-1999 07:13:08
 Re: loader removal in reply to lh, 10-10-1999 18:08:07
To remove the loader you must jack it onto supports after unbolting and then back the tractor away from it. You will need supports for the front and rear of the loader. Make sure they are stable so the loader can't roll off or fall over. Retract all hydraulic cylinders and use a heavy coat of grease to protect any exposed cylinder rods from the weather. EEA
