Order Ford 8N Parts Online
8N wiring for new generator
gn1
10-09-1999 18:40:56
old generator took a dump new generator has three terminals and i,m told i need a 6volt battery help?
Claus
10-09-1999 19:15:02
 Re: 8N wiring for new generator in reply to gn1, 10-09-1999 18:40:56
Your comment is not to clear as what you need. How many terminals did the old one have? The 3 terminals on the generator are Ground, Armature, and Field. The armature terminal goes to the ARM terminal on the regulator. The Field terminal on the generator goes to the FLD terminal on the regulator. The Ground terminal goes to a good chassis ground usuall tied in the with ground on the regulator. How can I help you with the battery? Happy Motoring
Claus
gn1
10-09-1999 20:05:26
 Re: Re: 8N wiring for new generator in reply to Claus, 10-09-1999 19:15:02
the tractor had a 12 volt battery installed some time ago by a previous owner i think thats why the generator failed the old generator had only one terminal went to nseries and have found the after sn 263843 diagram i am assuming that i have to go back to a 6volt system if i use this generator?
Claus
10-10-1999 04:15:44
 Re: Re: Re: 8N wiring for new generator in reply to gn1, 10-09-1999 20:05:26
Single post generators (3 Brush) are 9N/2N vintage and are employed using a cutout relay. 3 terminal, (2 Brush) generators come in 2 flavors, 6 volt and 12 volt and need a voltage regulator to function properly. 12 volt generators are not original equipment on the 8N, but some aftermarket suppliers have them. The voltage of the generator has to match the voltage of the battery, otherwise the system cannot function properly.
Hope this clears up the mess..
Happy Motoring
Claus
