9 n ford
chris
03-01-2000 18:42:52
my 9 n runs fine for a while this i haft to pull the choke to make it run and when i push the choke back in it will dye i did have some trash in bottom of gas tank so could some thing be getting hung in the carb making it do this ?
Jim(UT)
03-01-2000 19:13:45
 Re: 9 n ford in reply to chris, 03-01-2000 18:42:52
Hmmmm, do I hear a vote for a hole in the manifold? John? Nolan?
Mark B (WI)
03-01-2000 19:21:47
 Re: Re: 9 n ford in reply to Jim(UT), 03-01-2000 19:13:45
My N also needs the choke on part way to run good, I rebuilt the carb, sprayed carb cleaner around the carb & intake to see where it was sucking air and came up with nothing. How can you tell if the intake is bad?? any help is appreciated. Mark B 9N #38126
Joel-So Cal
03-02-2000 05:24:05
 Re: Re: Re: 9 n ford in reply to Mark B (WI), 03-01-2000 19:21:47
My 2N acts the same. I've done the carb, gas tank, distributor, in-line fuel filter, not sure what's left. I know it didn't run this way off the showroom floor. Found that there wasn't a thermostat... added that.
Confused....
Now you done it!!!!
03-01-2000 20:24:19
tOGT, you've started a monster here.....
