Order Ford 9N Parts Online
9n Brake Problems
Dewey
10-07-1999 08:24:19
I KNOW THE 9N IS NOT FAMOUS FOR ITS BRAKES. MY DAD PUT NEW LININGS ON ONE SIDE A FEW YEARS BACK, BUT THE BRAKES WERE ABOUT THE SAME[ NO BRAKES ]. BUT I NOTICED THAT THE METEAL PART OF THE SHOE WAS WARN DOWN ON THE U SHAPED PART OF THE SHOE WHICH SPREADS THE SHOES. QUESTION IF I REPLACE WITH BRAND NEW SHOES WILL THIS HELP MY BRACKES. QUESTION SHOULD I REPLACE THE SPRINGS EVEN THOUGH THEY LOOK OK.
THANKS
Nolan @erols.com
10-07-1999 11:29:10
 Re: 9n Brake Problems in reply to Dewey, 10-07-1999 08:24:19
I respectfully disagree about these machines inherently having weak brakes. Quite the opposite, when working right they have about the strongest brakes I've ever met on a tractor.
Will the wear on the shoes cause them to not operate? I doubt it. As long as the cam can jam the shoes up against the drum, energy will be transferred.
So I would be looking at a thorough cleaning first. Don't trust appearances, that which looks clean and dry can be quite oil soaked. Clean the drums, clean the shoes. I would start with ordinary soap and water with a scritcher scratcher type of sponge. Then switch to carburetor cleaner, and then use brake cleaner. If you are at all suspicious of glazing, use sand paper after the soap and water, then repeat the soap and water a second time.
As another pointed out, if the drums and shoes are ridged, brake effect is compromised. The more the ridging, and the deeper the valleys, the worse the compromise.
I would also look at the drums for signs of belling, and the shoes for warp and twist and wear. If the shoes cannot make good contact along their entire length, brake effect is compromised. And if they can only make full contact by doing a twisting and bending, again brake effect is compromised. The shoes should go up squarely against the drum, with a minimum of motion, and no cocking or twisting required.
I would also be very consientious about adjusting the brakes. As in doing it right. Now on mine a proper adjustment (automotive proper) resulted in a very firm and high pedal, but a near instant grabbing and locking. So I ended up adjusting out giving my a sloppier pedal, but more feathering control of the brakes. If your brakes are out of whack on adjustment, they will not work as well.
Dennis N Tx.
10-07-1999 12:34:28
 Re: Re: 9n Brake Problems in reply to Nolan @erols.com, 10-07-1999 11:29:10
On the subject of brakes.
On my 8N the right pedal was very low compaired to the left and didn't have much braking in it. I removed the knock out from the backing plate and adjusted the brake. It now has wonderful braking. The pedal is still lower than the other and it seems as if the shoe is rubbing the drum when its rolling. It makes a noise as if you were barely applying the brake. I didn't like this so I got a bungee cord to hold the pedal up. I have never had the rear wheels off, so I don't know how the system is configured, the I&T shop manual doesn't show a good picture of braking assembly. I guess my question is, does it sound like a spring (which holds the petal up) has come off, broken, or stretched....if it has one....or does it rely on the typical brake shoe springs to hold the petal up?
Any ideas will be appreciated!
Thanks
Dennis
8N48II82
Nolan @erols.com
10-08-1999 03:44:38
 Re: Re: Re: 9n Brake Problems in reply to Dennis N Tx., 10-07-1999 12:34:28
Yes, the brake shoe return spring is the spring that brings up the brake pedal. So just a little bit of friction from rust and crud will cause it to not do such a good job of returning the pedal.
Ford did change this eventually, as Craigs 3000 tractor has return springs, with the same looking rear end as the N.
Go ahead and pull the drum off and take a look at it. It's dirt simple, and could undoubtably use some tlc, or at least some cleaning. The shoes are held onto the backing plate with the usual spring loaded pins. They are held retracted by a return spring. This return spring is limited in how far back it pulls the shoes by the star wheel adjuster that spreads the shoes apart. And the brakes are actuated by the rod turning when you press down on the pedal. The end of the rod is flattened. So when the rod is turned, the sides of the flattened area push out, acutating the brakes. That's all there is to it.
I personally think your bungie chord is a good idea. As I suspect quite a few N's out there are constantly dragging their brakes for lack of adequate brake pedal return. A positive return like the bungie will take care of this.
Rick
10-09-1999 23:15:05
 Re: Re: Re: Re: 9n Brake Problems in reply to Nolan @erols.com, 10-08-1999 03:44:38
I have a 9N and painted it last winter and would liked to have worked on the brakes when I had the wheels off. The left brake works fine but the right...well it could be better. I have adjusted both brakes.
My question is how to take the brake drums off? Mine's a 43 version...I think. Thank you.
Thanks.....Dennis N Tx.
10-08-1999 05:19:46
Another item to add on my never ending to do list.
David (La)
10-07-1999 09:35:40
Check the drums also, if they have ridges then braking will be compromised. Having them turned will give new brake shoes a flat surface to mate to and provide the best braking.
Timk
10-07-1999 14:14:52
 Re: Re: 9n Brake Problems in reply to David (La), 10-07-1999 09:35:40
Unless you know for sure that the brake shoes are of recent variety, I would not sand them, heat them, or mess with them, since the older brake shoes contain asbestos. Toss 'em an buy new. My 2 cents.
Nolan @erols.com
10-08-1999 08:25:41
 Re: Re: Re: 9n Brake Problems in reply to Timk, 10-07-1999 14:14:52
Just so you know, you can handle asbestos quit safely with just a filter. Its danger is respatory, from its friability. The particulate filter mask keeps those particles that float up from being inhaled. A wet washdown keeps the particles from floating up in the first place. And asbestos is still used in many brake shoes and pads. New ones may not be any safer then the old ones.
