Order Ford 8N Parts Online
8N WILL NOT START
GENE ZIEMER
10-07-1999 06:12:45
HAVE PROBLEM WITH FUEL GETTING TO THE CYLINDERS. REBUILT THE CARBURATOR NEW FUEL BOWLS AND FILTER. RECIEVING PLENTY OF GAS AT THE CARBURATOR. THE MAIN ADJUSTMENT SCREW ON CARBURATOR IS ON TURN OPEN. GAS AT THE ELBOW FOR THE AIR INTAKE. LOTS OF SUCTION.
Dave in Mo
10-08-1999 10:04:31
 Re: 8N WILL NOT START in reply to GENE ZIEMER, 10-07-1999 06:12:45
Gene, Generally speaking, an any piece of machinery, the weak link will be the electrical system, not the mechanical system. For this reason I always check for spark first. Battery could be quickly checked, then check the ignition switch (not the starter button) etc on down the line--points, wires etc. Weak link on my 8N was the keyed ignition switch. Good hunting.
David (La)
10-07-1999 08:59:42
I would like to help, but feel that I need some more information.
Have you checked the spark at the plugs?
Was it running before the work on the carb?
