2N,rear axle seals
Buford
10-05-1999 08:30:27
2N,rear axle grease seals leak.I've changed them twice,in a short period of time they allow grease
onto the brake pads.Any suggestions,Tx for any help
Buford
10-05-1999 11:12:33
 Re: 2N,rear axle seals in reply to Buford, 10-05-1999 08:30:27
Thanks Zane,I'll give that a try
JerryU
10-05-1999 09:53:24
I know Zane is not a fan of Sure Seals (mfg by TISCO) and don't know if that's what you are referring to, but I put mine in about 3 years ago in my 9N and they haven't leaked yet. For them to work, though, everything has to be clean and smooth. Especially the axles. I had to wire brush one and fill the pits with JB Weld and sand smooth for the seal to run on. Any grooves or pits will destroy the seal.
Really need a little more information.
ZANE
10-05-1999 09:49:17
I need to proof read my material more often.
I meant to say wrap the axle with teflon tape.
ZANE
10-05-1999 09:46:50
To fix the leak my unconventional way you pull the axle away from the axle housing about 6 or 8 inches and wrap the axle for about 6 inches from the outer end of the axle that is exposed Wipe all the oil from the housing and then take a caulking tube full of silicone glue and pump it into the void between the axle and the housing. Keep the hub as close to the housing as you can till you get the silicone pumped in.Use the whole tube and then replace the axle into the housing and replace the bolts etc. Let the silicone cure overnight and then you can go about using the tractor. Be sure that the oil in the rearend etc is not over full as this will contribute to the axle leaking.
