Leaky rear housing
Mark B(WI)
10-03-1999 17:39:05
My 9N #38126, is leaking hydraulic fluid from the rt. lower link arm bracket on the rear axle housing. I know there is a bad seal there, but how do I remove the lower link shaft to replace the seal?? Does it thread into the rear housing?? Your wisdom is anticipated. Mark B
ZANE
10-03-1999 18:02:50
 Re: Leaky rear housing in reply to Mark B(WI), 10-03-1999 17:39:05
The lift link must be accessed by removing the wheel, axle and houing in order to remove the nut that holds it in the housing from the inside.I hate to tell you this but most of the time you will find that there is really no good and easy way to fix this problem short of taking the housing to a machine shop and haveing a busging make to replace the worn hole in the axle housing.
If I were going to go to this trouble I would buy a link pin for the 8N and have the housing machined to fit it.The 8N pin is tapered and will stay tight and the 9N and 2N are straight and tend to work loose and wallow out the hole till a new pin will not fill up the hole.
You might get lucky and not run into this problem and a new 9N pin might tighten and not leak but I wouldn't count on it.
