Order Ford 8N Parts Online
8n oil filter
kevin-mo
02-29-2000 17:57:57
i was told that napa has a good oil filter for the 8n? would somebody give me that number. thanks
I wonder where these came from?...bg
03-01-2000 21:12:08
 Re: 8n oil filter in reply to kevin-mo, 02-29-2000 17:57:57
Baldwin P40Big A 92010 Bosch 72127 Carquest 85010 Fleetguard LF574 Ford CPN 6731B 9N-18649, 9N-6714, 9N-2731 Fram C-3 C-3P Hastings Mighty M3LF-130 Luber-Finer P3 Motorcraft FL144 NAPA Gold 1010 Purolater L 20110, L20701 Texaco HSO 100 P 70 FR Unocal 76 OF 1010 White 10575 Wix 51010 Fleetrite LFR-8574
Randall(AL)
03-01-2000 11:28:48
I like the Motorcraft FL1A.
Gaspump
03-01-2000 12:53:40
 Re: Re: 8n oil filter in reply to Randall(AL), 03-01-2000 11:28:48
Just curious, how did you get the FL1A to work on an 8N?
Randall(AL)
03-02-2000 05:59:24
 Re: Re: Re: 8n oil filter in reply to Gaspump, 03-01-2000 12:53:40
It's a NAA with the spin-on plate. After that you hold the filter and get two other guys or hefty gals to turn you around while holding the filter real tight!!!!! Heee-heee
Brian in S. IL
03-01-2000 09:24:11
Or try Fram C3P.
Brian in S. IL
03-01-2000 09:23:54
Or try Fram C3P.
Russ(NM)
03-01-2000 07:16:00
Also, Purolator L20701
Ed Gooding (VA)
03-01-2000 03:20:34
Hi Kevin: Try NAPA 1010.
Hope this helps..... ..... Ed
'52 8N475798
