Order Ford 8N Parts Online
2N and 8N horsepower differences
David
09-28-1999 19:48:14
I was looking at spec for the 2 and 8N engines. Bore and stroke are the same and numerous parts are the same. So where does the extra 5 horsepower of the 8N come in? Cam differences? Are all 8Ns higher horsepower or is it the ones with the side mount distributor? Anybody know the answer?
Charlie in TX
09-28-1999 21:10:50
 Re: 2N and 8N horsepower differences in reply to David, 09-28-1999 19:48:14
I believe the 9N/2N and early 8N, with front mount distributer, had 6:1 compression ratio. The later 8Ns were 6.6:1.
So then that would be a difference in the head?? (steverOH)
09-29-1999 05:15:54
 Re: Re: 2N and 8N horsepower differences in reply to Charlie in TX, 09-28-1999 21:10:50
are the pistons different or is the head different?
Bernie in S. Deerfield
09-29-1999 10:09:58
 Re: Re: Re: 2N and 8N horsepower differences in reply to So then that would be a difference in the head?? (steverOH), 09-29-1999 05:15:54
From what Ive seen it seems to be a pop up piston
bg
09-28-1999 20:01:28
the 9/2 bore was 3.187 and the 8n 3.188. They changed to aluminum-alloy pistons. The difference probably was more based in marketing than in engineering.
