AfterMarket Front Grill Assembly
Mark
02-28-2000 18:07:15
How much modification is necessary to fit an aftermarket grill to a 1941 N? I'm not looking to produce a parade tractor, just wanted something to keep the brush out of the radiator. I have the grill but the angle seems wrong, the height doesn't work and the shape of the hood doesn't match. I could make it fit by cutting it down and re-shaping it. Is that how everyone else does it?
Any info appreciated.
Mark
DE
02-29-2000 10:19:51
 Re: AfterMarket Front Grill Assembly in reply to Mark, 02-28-2000 18:07:15
In many cases, these old tractors have been beat up and the sheet metal twisted, bent, and contorted to the point that nothing short of a custom made grill will fit properly. I know a new EOM grill would not fit mine perfectly. You may have to loosen up some of the sheet metal bolts before you fit the grill in - this helped me fit a used EOM grill in mine. Still had to do some reshaping of the grill to get in in. Good luck.
Gary
02-29-2000 06:58:04
After restoring an old car, an old truck, and now an 8n, I have found that the quality of parts varies a lot. I try to find original parts first, then good used parts, and finally the repro stuff. I think that most parts, except OEM stuff, is a notch or two lower in quality. I don't go to the discount auto parts stores anymore except for oil, etc. I have found a place that does a lot of business with the local repair shops in my town. They are not the cheapest, but the quality is a lot better.
jon
02-28-2000 21:13:21
No real help to your question, but I don't understand why anyone making aftermarket parts would not make them to exact specs....I mean, they're going to make them a certain size, so why not make it exactly like the original. Can't see where it would be any more trouble unless it's a copyright thing. Any idea's?
Sam Neb
02-28-2000 18:18:41
With all after market body parts you must bent, twist, shove and push to make them fit. You just might get it to fit but you wont be able to take it to the County Fair.
Cort in Montana
02-28-2000 19:39:35
 Re: Re: AfterMarket Front Grill Assembly in reply to Sam Neb, 02-28-2000 18:18:41
I installed an aftermarket hood, grill and hood dogs on my 43 2N, and they all bolted up fairly well to the tractor. I had to shim the radiator with some plywood to get the neck to the correct position above the hood, other than that all was easy. I'd be inclined to say mixed and matched OEM and aftermarket is bad. A guy should probably go all OEM or all aftermarket.
Regards,
Jim(Ky)
02-29-2000 06:03:52
 Re: Re: Re: AfterMarket Front Grill Assembly in reply to Cort in Montana, 02-28-2000 19:39:35
I bought an aftermarket repro radiator cap with the "wing" on it. The wing was ok but wasn't deburred and may have been a little larger than oem. The pressure cap part was tin junk. I drilled out the spot welds and pop riveted a Stant cap in its place. This piece of garbage was made in India. It could cause you to break down in the field or allow the antifreeze to weep out. My watch has a stronger spring than that cap did.
dave(47 8n)
02-29-2000 15:00:51
 Re: Re: Re: Re: AfterMarket Front Grill Assembly in reply to Jim(Ky), 02-29-2000 06:03:52
the cap is not suppost to have a strong spring, the cap for the 8n is designed to let pressure off when the system goes over 3 psi..
Dave
Jim(Ky)
03-01-2000 07:06:29
 Re: Re: Re: Re: Re: AfterMarket Front Grill Assembly in reply to dave(47 8n), 02-29-2000 15:00:51
I know that. I got a real cap. I folded the other one up in my hand like paper.
