3pt Lifts except under load...
Johnny
09-25-1999 21:14:51
Have a 41 9N and her hydraulics seem to work perfectly until attached to a load. She will then struggle very hard to lift, not lift all the way and you can hear a mechanical "rumbling" from the pump housing. Have already replaced the fluid with the "expensive" Ford stuff. Is it the relief valve or a badly scored lift ram???
bg
09-26-1999 00:58:34
 Re: 3pt Lifts except under load... in reply to Johnny, 09-25-1999 21:14:51
Open the right side inspection plate and see if any fluid is flooding down from above, or see if there is turbulence down in the rear of the sump. The pump itself may also be worn or have a crack in it. Check each component by process of elimination. You can do a pressure check on the pump if the two conditions you mentioned(symptoms above)don't exist.
