Order Ford 8N Parts Online
8N TIMING?????
Dutch
09-24-1999 17:00:20
Boardmembers - is there a special trick to timing a 1952 8N. I put in a new distributor and followed the instructions in the owners manual and I can not get it to run on time. Please help me out
DonD
09-24-1999 18:04:51
 Re: 8N TIMING????? in reply to Dutch, 09-24-1999 17:00:20
There are two timing marks on an 8-N flywheel. You need to take out #1 sparkplug and feel when it is on the compression stroke and then ckeck the flywheel and that is the timing mark you use. I had the same problem till I found that info burried in the text. Good luck. Don
