Order Ford 8N Parts Online
8N Serial #
Eric Nelson
09-24-1999 09:49:09
Hello, I have a question about my 8N. The question I have arises in the age of the tractor. My father has always said the tractor was a 1952. However, I attempted to check the serial number on the 8N. When I looked on the left side of the engine at the hand stamped number, what I found was the following * 8N 354 Ib-5 *. The number very clearly has a capital I and a lower case b followed by a - 5. Is this possible? Did I find the correct number? The stars would indicate that the tractor was built before 52 (or at least very late in 51). However, the tractor does have the multi-function proof meter. It also has a step-down, standard, step-up Sherman transmission ( 12 forward, 3 reverse gears). Any information you could provide my would be greatly appreciated.
Jim(UT)
09-24-1999 09:59:04
 Re: 8N Serial # in reply to Eric Nelson, 09-24-1999 09:49:09
Ford used a screwy font on it's serial numbers. a "one" (1) looks like a capital I and a "six" (6) looks like a lower case b. Thus your serial number is *8N354165*. Check the link below to determine the exact year. You're lucky the number is still visible. Many are not.
