8N 12 volt problem
no longer charging!
Bob Stallard
02-28-2000 12:59:16
Dear Tractor Gurus,
About 2 years ago, I installed a 12v conversion kit on my 1950 8n. It proved to be a great addition for many reasons. Recently however, it seems I can't get the alternator to "excite", and therefore it doesn't charge the battery. I'm unsure what has happened. I checked all wiring and all seems OK. But no matter how high I run the RPM's, the Alt won't excite and doesn't show a charge on the Meter.
The engine starts fine, runs fine, but I have to charge the battery after running it..
Any thoughts or suggestions?
Thanks,
Bob
Claus
02-28-2000 13:39:58
 Re: 8N 12 volt problem - no longer charging! in reply to Bob Stallard, 02-28-2000 12:59:16
You did not say if you have a single wire jobby or the two wire with jumper. You need a voltmeter and with the switch on (Engine not running) measure the voltage at P1, P2 and Alt output terminal. (I assume that you have the popular Delco SI Series. You should have 12 volts at all three terminals. If you do, then start the engine. Take a small screwdriver and stick it in the little hole in the back of the altinator to ground out the tab on the voltage regualtor. If it is now charging, you have a bad voltage regulator. If not, you may have a bad altinator.
Happy Motoring
Claus
