Order Ford 8N Parts Online
8n starting problem
Jeff
02-28-2000 12:57:11
When I push the starter button the starter motor turns but doesn't always engage the flywheel and turn the engine over. I've replaced the bendix drive and it's no better. Sometimes the engine will turn and sometimes the starter just free wheels. What else could be wrong?
Dell (WA)
02-28-2000 17:53:57
 Re: 8n starting problem in reply to Jeff, 02-28-2000 12:57:11
Jeff..... while it doesn't make sense, DON'T EVER oil the Bendix drive, as even a little bit will turn "gummy" and slow down the gear engagement extension spin just a little bit so that the gear won't get to the flywheel ring before the starter is at max RPM's and will not engage the flywheel. Squeeky clean and dry for the Bendix drive. Hope this helps..... ...Dell
Mark (AR)
02-28-2000 16:15:12
Zane has the answer.. Mine did the same thing, even with new bendix. I am not useing an alternator, just charging battery as needed. When it gets low, the starter will not turn fast enough to engage the ring gear. I hope that yours is this simple..... .
buck
02-28-2000 16:02:51
good comments so far To isolate the problem you may want to turn the engine a little by hand before you attempt to start. the engine always seem to stop at the same place and that is where the damage to the ring gear may be. good luck
ZANE
02-28-2000 15:07:45
Sounds to me like you have a weak battey or some bad connections or bad battery cables.
Allen
02-28-2000 13:09:03
Question is did you used the heavy duty starter bendix? The standard unit is one diameter on the tooth end, while the HD has a fair bulge that you would remember. Problem is that you will need to hand grind the opening (1:00 to 3:00 area) to allow fit. Another issue is the condition of the flywheel gear. If it is worn it can be replaced, but that involves splitting the tractor and a good torch.... Life ain't always easy, but it is fun!
