Johan.bakker@unisys.com
Zane Thang - te
09-22-1999 17:46:39
It arrived as promised.
It goes on in 10 minutes, as promised.
It takes a further 10 minutes to make minor adjustments, as promised.
Then it works, as promised.
I tested with 800# of lead bars - thank you, Zane.
It still works, as promised.
It should be made clear that it does not give you position control in just the same way that an 8N does. But it gives you position control. It will correct for leak down automatically. No modification whatever is required to the tractor.
Well made of laser-cut stainless steel, machined plastic and quality hardware - all Nylock nuts, grade 5 bolts, etc.
Instructions included an apology for marginal copy quality of photographs but all was clear. Money-back guarantee.
A stroke of near-genius. Zane, my friend, the ol' Resistol is tipped to you. Folks, you want position control on your 9N/2N, see Zane Sherman. The line forms to the right.
llater,
llamas
Is it Y2K compliant?, Jim (MO)
09-24-1999 07:56:08
 Re: johan.bakker@unisys.com in reply to Zane Thang - test report, 09-22-1999 17:46:39
Jim
09-23-1999 17:12:27
Lets see a picture of this magic trick!
ZANE
09-22-1999 18:10:41
Thanks Johan for the good report.I consider your report a very high compliment and I appreciate it.
Zane Sherman.
MERLIN/ZANE; where does the line form???? TX'n
09-22-1999 21:18:38
 Re: Re: johan.bakker@unisys.com in reply to ZANE, 09-22-1999 18:10:41
