Loader for Ford 8-N
Wayne Jones
09-21-1999 02:44:24
What would I need, how much would it cost, and where could I find a front end loader for a 1952 Ford 8-N. How well do they work and how difficult are they to install. Thanks for your help!
mark fuss
06-13-2000 06:36:01
 Re: Loader for Ford 8-N in reply to Wayne Jones, 09-21-1999 02:44:24
If you go to this site you will find brand new loaders for around 1450.00
stuart
09-21-1999 13:54:00
I recently put a loader on my 8n. It cost $1200
and that included the loader,rebuilding the cylinders and installation. I would recommend staying away from the old "pipe" style. Also just food for thought that on an 8n steering becomes a real job especially when the bucket is full Even thou the loader makes steering harder and servicing the tractor takes longer I would never even consider taking it off. The benefits far out weigh the drawbacks.
Hope I've been of some help.
Nolan
09-21-1999 08:56:53
I have an old Wagner on mine. It does work, but it brings with it a whole passle of problems. With the loader on, the tractor is virtually impossible to work on. You can't get to anything, including the gas cap. It makes the tractor flat dangerous to mount and dismount. I've hurt myself several times getting on and off because of that blasted loaders frame. It makes the tractor swing and wallow when you drive it. And greatly reduces rear wheel traction. I have to use heavy counterweights out back to hold the rear tires onto the ground.
I do think a loader can work on an N, but several points should be addressed. 1, the tractor is very light, so a heavy loader is overkill for an N, and will cause lots of traction and steering problems. You would almost want a lawn tractor loader mounted on an N to not overwhelm it.
2, Get the bucket back close to the tractor. The old units have the bucket many feet out in front, where the pendulum effect is made far far worse then it needs to be. A loaded bucket that sits back closer to the tractor will not swing the machine around like a loaded bucket sitting six feet in front of the tractor. Set back it also won't try to lift the rear tires off the ground as much.
3, use a modern design framework. As in a heavy vertical mount at the dashboard, nothing in the way of the operator area, and the bent down arms for the bucket itself. This will allow you to mount without danger, allows you to work on the tractor itself, and gets the load back closer to the tractor.
With that in mind, the two that come to my mind as possibles are the Paulson and the CadPlan models. The Paulson is a very nice looking unit, but it uses the onboard hydraulics and a trip bucket. That limits it greatly, and makes it slow. Though it could be made better with the addition of auxiliary hydraulics. The CadPlan one is nice too, using live hydraulics, but they want you to use a very large loader on the N. One that I really think is too large for the tractor.
If you're clever with a torch, you could certainly adapt virtually any loader you find at an auction onto an N.
Mike
09-21-1999 08:16:53
Lots of guys bad mouth loaders on N's but I have an original Dearborne on mine and would not part with it. Instalation is simple, two brackets bolt to the rear axle housing where the fenders mount and another bolts to the front piviot on the front axle, you will also need a splined front hub for the engine to run the pump and that is about it. To remove the loader you remove the 2 quick release pins at the rear and one bolt at the front, support the loader and back the tractor out, your done, re install is reverse.
A Dearborne will go for 500.00 in AZ and with any old loader they need some work. Mine has a trip bucket which works fine for me. Also Dearbornes'look right on the N's. Some people do not like getting on and off the tractor with them but tooo bad.
Just remember they are not heavy duty work horses that were designed for loaders, keep the work light and do not try to move mountains and they do just fine.
Don D
09-23-1999 05:57:10
 Re: Re: Loader for Ford 8-N in reply to Mike, 09-21-1999 08:16:53
Mike, I just bought a Dearborn loader for my 8-N and am interested in the quick release you said you have on your loader. Mine does't have that. I would have to unbolt it to take it off. Did the quick release come with yours? Can I adapt mine to have that feature? Thanks for any info-Don D
Jim(UT)
09-21-1999 08:07:29
I have an old Wagner loader for sale. Email me your address and I'll send a pic. Sorry, no scanner and no smarts. I still have to send pictures the old fashioned way.
Patrick Andrzejek
08-20-2000 14:11:14
 Re: Re: Loader for Ford 8-N in reply to Jim(UT), 09-21-1999 08:07:29
Do you still have your wagner loader for Ford 8N
My mailing address is
Patrick Andrzejek
HC 13 Box 42A
Sparks, Nebraska 69220
jack swanson
10-24-2001 16:17:24
 Re: Re: Re: Loader for Ford 8-N in reply to Patrick Andrzejek, 08-20-2000 14:11:14
i also have a wagner for 8n 9,2, to30
nice red paint complete with hyd.bucket ,pump
valve control. it will need a splined front hub to run the pump
Evan MacDonald
09-22-1999 17:55:54
third party image
Jim, does it look like this? Thats my Ferguson TO 35 in the background.
Evan MacDonald
PMHaas
09-21-1999 03:24:30
One I know of can be seen at www.paulsonloaders.com
