Order Ford 8N Parts Online
8N generator pulley
Steve (IA)
09-14-1999 16:37:11
Is there an off the shelf replacement for the generator pulley? CT catalog lists them for $19.95 and that seems a little steep. Anybody had any look finding a suitable lower priced subsitute? This is the woodruff key pulley, BTW.
Thanks. Steve
WT
09-15-1999 06:03:27
 Re: 8N generator pulley in reply to Steve (IA), 09-14-1999 16:37:11
I hope it works out for you in the end somehow. I looked high and low for some sort of substitute. Never did find anything. I finally settled on a $40 replacement from Walt's.
Wish I had known about the $20 pulley that you're talking about.
Jim
09-14-1999 18:42:39
Try a 40-48 Ford car gen pulley. They screw on right over the key slot. I just put a 49-53 car gen with a truck wide belt pulley on a stock 8N bracket, fit just fine.
ZANE
09-14-1999 18:16:42
If you can find any alternator pulley that will fit the shaft and line up properly with the othe pulleys you can disregard the woodruff key arrangement. All you need to do is tihgten the nut with an impact wrench and it will stay on just like they do now days on alternators.
