Order Ford 8N Parts Online
8N Box Blade
Mike/AZ
09-13-1999 21:51:15
What is the largest box blade that should be used behind an 8N with a 3 speed Sherman?
ZANE
09-14-1999 03:29:10
 Re: 8N Box Blade in reply to Mike/AZ, 09-13-1999 21:51:15
I would think a 6ft would be about as large as it would easily handle. You need it to be wide enough to cover the width of the rear wheels. YOU would have to have extra weight in the rear wheels such as water or wheel weights to improve traction.
David (La)
09-14-1999 09:44:43
 Re: Re: 8N Box Blade in reply to ZANE, 09-14-1999 03:29:10
I have a 5' box by howse and I can easily take a bite too big with new ground and spin the tires. Once loose though it will push (pull) a full load!
Mike/AZ
09-14-1999 08:32:30
That is about what I figured would be the maximum limit as I was looking to cover the width of the tractor. Thank You.
