9 n ford oil pressure
chris
02-26-2000 13:06:37
what should my oil pressure be when the engine is first started then what should it dron to when warm . im getting about 45 pounds when i first start the engine then as it warms up on it drops to about 15 or 20 pounds . so i need a new oil pump ? and is this some thing i can change my self ?
Roger
02-27-2000 13:22:43
 Re: 9 n ford oil pressure in reply to chris, 02-26-2000 13:06:37
It seems to be OK.
Ford's manual says 25 psi at 1800 rpm when engine is at operating temperature.
Fred Martin
02-27-2000 11:46:54
Chris, I'll address the other end of this (like Gallagher) I have observed different oil pressures with different oils. In fact, I've seen oils that I drained out at change time that carried more pressure than the new oil that I just put in. It was a different brand of the same weight. On an old engine (clean inside) I tend to use 10W40 multi-vis oil. It seems to hold more pressure when it warms up than the old straight 30Wt. I been using oil that you have to turn your head when you put it in cause it pours just like water but carries good pressure and seems to do the job for me. Must be okay, Pennzoil bought them out recently. Some of you old timers will probably grin at this one knowing what one I'm talking about.
If It Ain't Broke-------------
02-26-2000 13:47:24
As my Grampa used to tell me: If it ain't broke, don't fix it. It sounds to me like your N is happier'n a hog in slop. Doesn't sound broke to me. I'd just enjoy it and wait for a break to come up.
FWIW----- ---8>)
ZANE
02-26-2000 13:58:39
 Re: Re: 9 n ford oil pressure in reply to If It Ain't Broke-------------, 02-26-2000 13:47:24
I would say amen to if it ain't broke don't fix it!
That is pretty good oil pressure for an N engine.
