You're welcome. If you are seeing milky white deposits in the oil filler neck, that's water (condensation or rainwater) that's got into the oil and is now emulsified with it. Obviously, that's not good, and an oil change is called for. The procedure for the "Perfect Oil Change" is cut-and-pasted below. This was a magazine article, from which I have edited extraneous stuff. Freddy is also telling you, by the water in the oil, that he's not running hot enough. This is only reasonable - his cooling system was designed to keep motor temperature down to about 180�F even when running under full load on 100� days. For the climate of Puget Sound (as I recall it) he has way too much cooling system, and he's running too cold. This may be compounded by some previous wise-ass having removed his thermostat. After he's run for at least 30 minutes, shut him off and immediately put your hand on the top and bottom radiator hoses. The top hose should be too hot to touch - 140-160�F. The bottom hose should be comfortably warm - 80-90�F. If it is not so, he's not getting hot enough to evaporate condensation in the engine oil and drive it out through the breather as water vapor. You'll need to check for a thermostat (post back for instructions). In the meantime, you'll help him a lot by screening the radiator, to reduce airflow and therefore cooling. The farmer's solution for this is an old feed sack, because it's partly permeable and reduces airflow without blocking it entirely. The woven fabric sold as "garden shade cloth" makes a perfect radiator screen for an N in temperate climates - it's close enough to screen the airflow but open enough that it won't clog easily with dust. HTH, llater, llamas Performing The Perfect Oil Change on your Ford 9N/2N/8N tractor The engine of your tractor may be powered by gasoline, but it runs on oil. The engine oil is circulated by a pump, which feeds it to all the bearings and things inside the engine that need it. The oil ends up splashing and splattering all over the inside of the engine, and in that process, it washes out contaminants, wear particles and general crud. Each time the oil passes through the engine, it also passes through a filter, which removes any particulate matter and sends the oil on its way refreshed and renewed. Oil wears out eventually � it breaks down with the heat of the engine, and it accumulates water and particulates too small for the filter to capture. For this reason, the oil needs to be changed regularly. The original Ford recommendation was to change the oil and filter every 200 hours of running, and that�s a good place to start. If you use your tractor in a very dusty environment, or your use tends to be lots of short excursions (where the motor doesn�t have a chance to get really warmed through), you should consider a more frequent oil change schedule � every 100 hours of running, or even more frequently. Each time you change the oil, you remove a certain amount of crud, debris and particulate matter. It�s like flushing out the engine. For this reason, a well-done oil change is the single most beneficial thing you can do for the life and health of the motor. Many people ask �what oil should I use�? This engine was designed in the 1930s, before modern, multigrade oils were available. The original Ford recommendation was for the use of straight, single-weight oils, the weight of the oil depending on the outside temperature. Nowadays, there are more options in engine oil. Opinions vary on the best choices, but a common approach is to use multigrade 10W30 oil when the temperature is expected to fall below freezing, and straight 30 weight oil when temperatures are not expected to be below freezing. For most climates in the US, this means two oil changes a year � once in the spring, once in the fall � and that usually fits in quite nicely with the recommended oil change intervals. Buy only high-quality, brand-name engine oil. It costs so little anyway that a few cents saved by buying some unknown brand is false economy. Remember also that changing the oil is a futile exercise if you do not also change the filter. The Perfect Oil Change is the easiest thing in the world to do. The problem is that oil changes are often seen as a chore, and the necessary time and attention are often skimped in the rush to get to something that seems more important. You may well be the first owner of the tractor to do this right. The first step is to get the motor good and hot. Run it for at least a half-hour, until the cylinder head is too hot to touch and the oil filter can is uncomfortably warm. This ensures that the oil is hot, which makes it flow easier, and it also makes sure that any crud in the oil is fully entrained and will come out with it. Park it, shut it off, and immediately remove the drain plug on the underside of the engine. Have a drain pan that will hold 6 quarts of oil under the drain. You�ll get a hot, oily hand, because the drain hole is big and most of the oil will come out in one big rush. Once that is draining, turn to the oil filter can, on the left side of the engine. Remove the cap by undoing the big hexagon bolt on the top. Don�t remove the filter yet. Next, locate the drain plug for the filter can � it�s on the bottom of the can, towards the front. It may have a hexagon head, or it may have a square head � either way, it�s usually all boogered up from people using pliers to remove it. Remove it, with a drain pan under the hole � this will allow the oil in the filter can to drain out. Now � go away and leave it alone. Find something else to do, but leave it to drain for at least an hour, and longer if it suits you. It will drip oil for at least that long. Stop by during this time and pull the oil filter out of the can � there�s a cute little folding wire handle on the top that you use to lift it out. The longer you let it drain, the more completely it will remove all the old oil, and all the nasty stuff that�s in it. There are things you can be doing in the meantime. The first involves the big drain plug you unscrewed from the bottom of the engine. It should have a cylindrical screen of fine wire mesh attached to it. Often, this is missing. If it is, you need a new drain plug. This screen protects the suction intake of the oil pump from nasty particles which will eat the pump in short order. Your tractor has been around for 50 years at least, and I guarantee you that there are bad things lurking in the pan of the engine � sand, even gravel, and other similar nasties. The screen is what keeps those things from eventually being sucked into the oil pump and causing you a large bill. So, if the screen is missing, get a new drain plug. If the screen is there, clean it off to a surgical standard. The best way to do this is with a volatile cleaner (like carburetor cleaner) and compressed air. Remember that the crud will be on the outside of the screen, so blow it off from the inside. Next, turn to the oil filter drain plug. These are usually in rough shape, usually because some user couldn�t find the right wrench to remove it and resorted to the pliers. If the plug is so battered that you can�t tighten or loosen it with a wrench, get a new one. It�s a 1/8� National Pipe Taper (Fuel) male plug, it will cost you less than 50 cents, and any plumbing or auto supply store will stock these. Steel, or brass, doesn�t matter. While you�re there, invest in a tube of pipe sealant, often called �dope�, which is marked suitable for oil and fuel systems. I prefer Loctite PST brand, but there are many good brands. Next, find the oil filter cap. Remove the rubber gasket from the inside of the rim of the cap. There�s a new gasket packed with the new oil filter. Clean off the inside of the cap and the cylindrical stem � again, carburetor cleaner and compressed air will do a fine job. Oil the new gasket with a drop of clean engine oil, and press it into the groove on the inside of the cap. Next, remove the oil filler cap from the fill tube next to the oil filter can. The inside of the cap is filled with a wire mesh material, and this needs to be clean. Some older cap styles are made to be taken apart, so you can remove the wire mesh and wash it clean. More modern styles do not allow this, but either way, wash out the mesh with a solvent like kerosene or carburetor cleaner, then blow it dry. Once you are happy that all the oil has drained from the motor, replace the drain plug. A thin layer of gasket compound on the plug gasket will help it to seal tight and prevent drips. Next, wipe out the inside of the filter can and remove all traces of oil. Install the drain plug, with a thin layer of pipe sealant on the threads. Drop the new filter into the can (handle upwards!), then fill the can with clean engine oil � this will �prime� the oil system and reduce the time that the engine runs with low oil pressure when you restart it. Finally replace the oil filter cap � don�t overtighten it. About a half-a-turn on the nut after the point that the cap gasket seats on the can rim is just fine. All that�s left now is to pour 6 US quarts of engine oil into the filler neck, replace the filler cap, and start the motor. Check the oil pressure gauge as soon as it starts � you will see zero oil pressure for a few seconds (because all of the oil passages are empty), but the gauge should rise to normal pressure within four or five seconds.
