Order Ford 9N Parts Online
9N (2N) Spark Plug Wires
Woody
09-10-1999 18:20:07
I need to replace the plug wires on my 2N. It has a front mount distributor and is still 6V w/ + ground. The plug wires on it now look like the modern automotive type. I would like to replace them with something close to original or better but would like to buy them local (not order). The Ford/NH dealer was really high $. What should I look for if I go to a parts house?
Any recommendations on plugs?
TIA
woodie
09-14-1999 10:47:24
 Re: 9N (2N) Spark Plug Wires in reply to Woody, 09-10-1999 18:20:07
Thanks for all the advice. I had intentions of buying the stock and making the wires. The guys at the parts house talked me into buying a set (6) of universal wires with the 90 deg plug ends all ready made up. The set was solid core (actually stranded). I fished them through the tube and was able to get the dist ends crimped on with the tube in place. I put 90 deg connectors on the dist end also. The two longest wires in the set could have been an inch or two longer but they made it OK. The whole ordeal was painless and it runs good.
This is a great list, there are not many places you can fire of a question and have a usable answer in an hour or so.
ZANE
09-11-1999 03:27:36
The original wires were in a steel tube that was held by brackets that were clamped to the head by two head bolts. The wire was stranded copper and none of the carbon stuff that is not worth the effort it takes to install them.To operate properly they don't have to be in the steel tube, but do have to be held so that they will not get to rubbing the fan belt.
TimK
09-11-1999 16:35:46
 Re: Re: 9N (2N) Spark Plug Wires in reply to ZANE, 09-11-1999 03:27:36
You're being penny wise and pound foolish. Get the wires from NH and make sure they are strung thru the steel tube that's supposed to be there. That will avoid future problems that happen when you take short cuts.
DD (wa)
09-10-1999 18:52:18
I just did mine not 2 day's ago. This is what I did. Bought 15-16 ft. of solid core plug wire from the local NAPA shop. Bought new short 90deg. spark plug boots and crimp-on ends for the plugs and distributor and 90deg. boots for the distributor as well. I then removed the wire tube that's above the head, the biggest part of the job, by far. It involved removing the wire harness from the terminal block, etc.
I then pulled the spark plug boots off the old wires, then crimped the end of the new wire to the spark plug end of the old wire and pulled each new wire one at a time through the tube. Use some WD40 to lube up the inside of the tube and to ease the removal and installation of the new boots. Leave extra wire at both ends.
Now the fun part, getting the wires cut and ends crimped to the right length. JUST DON'T LEAVE THEM TOO SHORT!!!!! !!!! Slip the boots on the wire, cut back about �" of insulation, fold back the solid wire, crimp on the ends.
Cutting and crimping is much easier to do while the tube is off the tractor but I'm sure it can all be done on it if the hood is removed. I have a problem getting my hood off right now so opted to remove the tube instead. Any wires you buy in a set would have to be pulled through without the boots on one end so this wasn't too much harder, just getting it the right length. I spent around $10-$11 for all the parts and took a couple hours to do the whole job.
Runs great and cured the intermittent miss.
Good luck.
