Order Ford 8N Parts Online
8n gas in oil
tony taylor
09-10-1999 14:07:21
i have an 8n thats getting gas in the oil it seems
to be flooding. any answers.
Jim Remillard
09-10-1999 14:47:48
 Re: 8n gas in oil in reply to tony taylor, 09-10-1999 14:07:21
Tony,
I had this happening on my 1956 8N. My oil pressure kept dropping lower and lower. I thought my oil pump was shot. Also, my oil level kept rising!!?? When I undid the oil drain plug to replace the pump the problem was obvious. There was so much gas in the crankcase oil that I could have poured it back into the gas tank. Anyway, the problem was that the spark plugs were fouling so that I wasn't getting complete combustion. Since it is an old engine the unburned gas just ran down the sides of the cylinders past the rings and into my crabkcase oil. When I talked to a mechanic who knows something about old Fords he said something convinving like "Yup! They'll do that..". I could solve the problem by getting the "right" spark plugs from a Ford dealer (with the correct heat ranges) but even they eventually fouled leaving unburned gas to slog into the crankcase. Then I got these spark plug adapters that screw into the block. The spark plugs then screw into the adapters. Apparently this keeps the spark plugs far enough out of the cylinder so they don't foul. Anyway it works. My spark plugs don't foul and I don't get nearly as much gas in my oil - at least my oil level goes down with time now instead of up. Good luck. Hope this helps!! JR
Joe@Ga.
09-10-1999 20:22:19
 Re: Re: 8n gas in oil in reply to Jim Remillard, 09-10-1999 14:47:48
Do you turn off the gas at the sediment bowl when the tractor is not in use? Sometimes the gas will leak into the crankcase if you don't have the fuel supply turned off. I turn my fuel off every time I finish working.
1956? 8N?.....Jim(UT)
09-10-1999 17:12:48
Maybe just a typo, eh? If it's a 1956 then it's probably a 600 or 800. If it's an 8N, then it's a 1948-52.
