Order Ford 8N Parts Online
8N Front Dist advance mechanism
Danti (CO)
09-10-1999 09:03:50
I just removed and cleaned the front mount distributor on my 8N. What type of lubrication is needed for the advance mechanism that is located just behind the breaker point mounting plate? It does not appear that this will get much (if any) engine oil lubrication.
Also there are what appear to be 2 vents, one on the bottom and one on the side of the dist housing. Do these require any special attantion.
Thanks for all the excellent advice from this board...
Claus
09-10-1999 10:04:13
 Re: 8N Front Dist advance mechanism in reply to Danti (CO), 09-10-1999 09:03:50
If you have the original cam and weights assembly, you will find a set screw in the back of the shafts. Remove this screw and you should find a wick inside. Remove this wick and oil it. Make sure the small hole in the shaft where the front bushing goes is open and not carboned up. On the back boss, there is an oil groove that likes to get carboned up also. I use a sharp instrument to clean it out.
