Order Ford 8N Parts Online
Alternator on an 8N
Claude
09-10-1999 07:39:38
On 9-6-99 @ 10:13 I posted a message about the alternator on my 8N (which was graciously responded to by Claus). I have a front mount distributor, 6 volt battery, negative ground with an alternator. Because the starter turns over slowly, and the tractor is hard to start I wondered if I should change over to positive ground because of the front mount, and I questioned whether or not I had a 12 volt alt. Since that posting I found a module wired to the side of the alt. that has 6 volt stamped on it (don't know what it is for). I tried to change the battery cables to positive ground but got a short. I'd like to change to positive ground but don't what to do, or if it's worth the trouble. Comments appreciated.
Nolan
09-10-1999 09:01:27
 Re: Alternator on an 8N in reply to Claude, 09-10-1999 07:39:38
Remember, a 6 volt system is very sensitive to resistance. Aka corrosion to the eye ball. Far more sensitive then a 12 volt system. So I would suggest a thorough cleaning of electrical connectors, starting at the battery terminals.
Now if I'm smart, I'll go home and apply this to my own hard to start, slow cranking tractor. As I do in fact know this is my problem. :-)
raytasch
09-10-1999 08:06:42
Claude, My guess is that the "short" you mentioned when you reversed battery polarity "toasted" the diodes in the alternator. fwiw, ray
Claude
09-10-1999 08:26:56
 Re: Re: Alternator on an 8N in reply to raytasch, 09-10-1999 08:06:42
I only touched the cable to the battery post long enough to realize there was a short. Would this be long enough to toast the diodes?
faster than a speeding bullet..........Dell (WA)
09-11-1999 08:37:33
 Re: Re: Re: Alternator on an 8N in reply to Claude, 09-10-1999 08:26:56
shorting out diodes makes fuses out of them. Remember, unlike lightbulbs, diodes very much care which direction the current goes. Therefore, alternators require special care and NEGATIVE ground. Used and checked out alternators at junkyards are $10-30. Just require a core..... .Dell
Claus
09-10-1999 08:01:57
Unless, you have an altinator specifically designed for positive ground, you cannot reverse the polarity of the battery. Altinators designed for positive ground are very rare. The fact that the starter mortor turns the engine slowly, is not indicative of a positive or negative ground. Take a volt meter and attach the leads to the starter motor when you are cranking. You should see about 5 volts when cranking. On a six volt system, make sure your battery cables are at least 2 gauge and are as short as possible. A lot of people replace them with 4 gauge which is ok for 12 volt but drops excessive voltage for 6. If you have a front mounted 6 volt coil they are designed for positive ground and you will experience some degradation with the spark current. Remove the inspection cover on the starter motor and observe the condition of the brushes and commutator while you are at it.
Good Luck Claus
Claude
09-10-1999 08:29:06
 Re: Re: Alternator on an 8N in reply to Claus, 09-10-1999 08:01:57
Thanks Claus. I'll check it out as you suggested.
Claus
09-10-1999 08:47:43
 Re: Re: Re: Alternator on an 8N in reply to Claude, 09-10-1999 08:29:06
After thinking about the external module that you have on your altinator, I would guess that it is an external voltage regulator to convert the altinator to six volts. This would be a poor man's way of converting a 12 volt altinator. The amperage capability stays the same however the wattage would half since the output voltage would be reduced but then how much engergy does one need anyway on a N series, not much ...
Claus
