A 2N needs help
Earl Park
09-09-1999 18:59:12
I have a 1944 2N SN:157269. On the instrument panel I have a oil pressure guage and a amp. meter on the right side of the steering wheel, what guage goes in the guage size hole on the left side of the stering wheel? Also on the left side of the steering wheel is a smaller hole, what was this hole originally for? In the Parts Manuel for 2N, 8N, 9N, NAA on page 153 it refers to a light swith bracket on bottom of instrument panel but on page 54 of the same manual there is a part called plug (light switch hole) button, I assume for this same hole, so were does the light swith go? I have lights but my 2N did not come wired, and there was no switch.
I want to thank all of you for the knowledge that I have learned from this board, I read and LEARN from it every night, keep up the GREAT flow of information.
Earl
TX'n
09-09-1999 19:52:12
 Re: a 2N needs help in reply to Earl Park, 09-09-1999 18:59:12
I also have a 1944 2N, SN# 139032 (my grandad's) and the oil pressure guage is on the right and the ampmeter is on the left. I have one plug on the left for lights, but the Ford dealership in Collierville Tennessee decided that they needed to drill a new hole for the light switch and placed it below the ampmeter and above/left of the light plug. In later years, when my dad took ownership, the lights were trashed and the switch was used for ignition.
Any chance you want to unload those lights? What I have for replacements are pretty lame.
Earl Park
09-09-1999 19:58:08
 Re: Re: a 2N needs help in reply to TX'n, 09-09-1999 19:52:12
If I ever decide not to restore my 2N I'll let you know. till then thanks for the offer. Earl
DD (wa)
09-09-1999 19:13:34
I have a 1946 2N and the small hole on the lower left side is for the light toggle. The plug must be for if it came without lights. As for the ammeter, mine is on the left side and I only have the oil pressure guage on the right. Are you saying you have three larger meter hole on your 2N?
Earl Park
09-09-1999 20:03:47
 Re: Re: a 2N needs help in reply to DD (wa), 09-09-1999 19:13:34
sorry after looking at some pictures i was wrong there is only two one on each side of the wheel. I was looking at the picture in the parts manual, and not my own tractor.Earl
