Battery almost blew up.
Griz in Pensylt
09-09-1999 17:52:36
Ordered a new rebuilt generator from CT. for the old 9n. Gave it to my brother to install on the tractor with the following instructions.
1. Install on tractor
2. Polorize by touching the output (single term) to the hot side of the battery (-)
3. Start tractor and adjust output screw for 2 -3 amps at operating rpm.
4. Mow the fields
This is what happened
1 and 2 were completed . Tractor started and ampmeter went to 30amps. Turning the adjustment screw only brought the charge current down to 10 amps min. Now not being the sharpest tool in the shed he mowed the fields and put the tractor away.
Next morning the battery was dead and when he went to take it out it was swelled up like a basketball untill it vented when he opened one of its filler caps. Now not being the brightest bulb in the lamp he charged the battery back up, drilled tiny holes in the fill caps reinstalled it and mowed the fields. Now i aint exactly a rocket scientist but there seems to be something wrong. And i gotta fix it cause i aint lettem near it again.
Questions?
a new wire harness and cutout was installed while we were waiting for the generator in the mail. could a miswire cause the generator to put out that much current I installed them and i'm pretty sure they were right.
He charged the battery before installing the generator could he have overcharged it? and this is causing the gen to overcharge (shorted cell?)
How much output adjusted to high do these generators put out? Tractor has 50amp gauge
And finally How do i check its output to see what its really doing? Voltmeter,Ampmeter?? Help!!
Nolan
09-10-1999 03:54:14
 Re: Battery almost blew up. in reply to Griz in Pensyltucky, 09-09-1999 17:52:36
Fwiw, I had an almost identical senario with my wifes truck a while ago. Had a bad cell in a brand new battery. The symptoms were the same as you've described. With the dead cell, the alternator worked itself to death trying to charge up that dead cell, boiling water off in the others. And while the truck would sit, that bad cell would drain the others.
Positively diagnosed by hydrometer. The one cell would at first barely come up to proper specific gravity, and quickly lose it. Later, the cell just would not come up at all.
It was a Sear DiHard for the record, and Sears refused to warranty it.
Claus
09-10-1999 05:04:32
 Re: Re: Battery almost blew up. in reply to Nolan, 09-10-1999 03:54:14
I would not let Sears get off the hook on that one. After years of using Sears Die Hard Batteries , I finally figured out what name meant. When they die, they die hard. Happy Moroting
Claus
Nolan
09-10-1999 06:01:07
 Re: Re: Re: Battery almost blew up. in reply to Claus, 09-10-1999 05:04:32
Once upon a time, that was true. Today, the DieHard is just the discount line of Exide.
Claus
09-09-1999 18:43:55
No scenario that I could think of would give those symptoms that you describe. First, the generator has a max output of 11.5 amps at 1500 rpm... and that is at full output with the adjustment of the third brush at max. If the battery charged and or overcharged why would it be dead in the morning. You must have a serious wiring problem. Are you sure that the ammeter is wired properly and you think discharging is charging? Is the cutout relay wired correctly? That alone though would not cause the symptoms you describe. Check it anyway, you should have no voltage at the generator arm terminal with the engine not running. Is the battery polarity correct? Start the tractor and measure the output voltage of the generator, it should be at least 6.5 volts although it could rise considerably higher depending on the charge of the battery.. The voltage should not get higher than 7.75 volts but with the non regulating type generator it is very possible for this to happen and then you could boil the electrolyte...
Good Luck
Claus
