8-n rear wheel left ,( to left of driver.)
Stan. Godell
09-08-1999 09:08:34
My left wheel sounds like metal against metal as i move. Squeels bad. do i need to install a bushing or bearing? Any help will be much appreciated
David (La)
09-08-1999 13:17:15
 Re: 8-n rear wheel left ,( to left of driver.) in reply to Stan. Godell, 09-08-1999 09:08:34
Shake the rear wheel side to side, it if has slack then your hub is worn out or loose, and allowing the drum to rub on the backing plate.
Nolan
09-08-1999 09:21:37
Pull the wheel off, then the drum. Odds are, you will then find a piece of brake hardware screeching against the drum.
