2N plugs?
Mike, CT
09-03-1999 22:36:02
Hi there, what spark plugs have you had the most luck with on a 2N? Suggested gap? thanks..
ZANE
09-04-1999 02:25:22
 Re: 2N plugs? in reply to Mike, CT, 09-03-1999 22:36:02
I like the AC plugs. Champions were the original equipment I think and they were good plugs then. Now however Champions are made of aluminum at the connector and will not stand corrosion.
If the tractor is not really heavily worked such as when plowing steadily for hours I would go with the hottest heat range plug you can get.This helps cut down on plug fouling when the tractor is lightly used.
