Order Ford 9N Parts Online
9N Gas Filter Woes
Cannon Cocker
09-03-1999 18:02:50
My filter bowl is vexing me. I bought a new bowl and cork gasket because the old one was chipped and leaked. Now if I tighten it up enough for it to quit leaking around the outside of the bowl, no fuel will flow. Seems odd to me because the place where the fuel drops out of the tube appears to be relatively far from the gasket. I've tried the recommended Napa synthetic gasket with no luck as well. Even tried using the old bowl with the two new gaskets, with the same poor results. Does anyone got any good fixes that that don't involve using duct tape? Thanks!
Po Folks
09-03-1999 18:20:16
 Re: 9N Gas Filter Woes in reply to Cannon Cocker, 09-03-1999 18:02:50
You fixed it! If gas flows when you turn it on, it would leak. Crank your tractor and the gas will come down as it is used. If by chance the carburetor and line is empty, unscrew the screw in the bottom of the carburetor enough to give it a little air and the gas will start flowing. Tighten screw and you are in business.
Weldon
09-05-1999 06:53:25
 Re: Re: 9N Gas Filter Woes in reply to Po Folks, 09-03-1999 18:20:16
You're in good shape. When you clean the sediment bowl and start to replace it, leave it loose and turn on the gas. When the bowl is full, tighten up the bowl just enough to stop the overflow of gas. That will make sure you have a good seal without crimping the gasket. Also the screw type fastener wont be so tight that you have to have pliers to loosen it next time you need to clean the bowl.
