1st 1/2 of throttle quadrant dead on 2n
erik
09-02-1999 17:35:19
The throttle on my 1945 2N doesnt respond when you move it in the first half of the quardrant. Also, It doesnt idle as low as it should. What should I do???
TAM
09-05-1999 22:07:32
 Re: 1st 1/2 of throttle quadrant dead on 2n in reply to erik, 09-02-1999 17:35:19
I have 2 2N's. Both of them have the same problem but it doesn't seem to hurt thetractor and I'm getting the full range of RPM's. I figure if it works I'm not inclined to mess with it.
Claus
09-03-1999 05:52:56
This is not a difficult problem to diagnose. Maybe the thought of a govenor scares some people. With the throttle lever at the low side of the quadrant, stand on the right side of the tractor and look at the linkage and the throttle plate connection. This is rod from the govenor to the carb. Does the throttle plate move smoothly when you go through the lower end of the quadrant? If not you have a linkage and or spring problem. The arm on the govenor where the throttle control rod is attached moves the carburetor arm through a spring. Both arms should move when you go through the quadrant. There should be no spring preload or slop in the mechanism. Let us know how you make out. It is best to follow paragraph 57 in the IT manual for the complete adjustment. Good Luck
Claus
Scares me, and I'm fearless...bg
09-03-1999 08:13:04
 Re: Re: 1st 1/2 of throttle quadrant dead on 2n in reply to Claus, 09-03-1999 05:52:56
Whenever I think of our Governor, Jim Hunt(NC), it's a scary thought...
RickH (IA)
09-03-1999 09:08:49
 Re: Re: Re: 1st 1/2 of throttle quadrant dead on 2n in reply to Scares me, and I'm fearless...bg, 09-03-1999 08:13:04
Hey, you could be from Minnesota. Then you'd really have a governor to be afraid of!! Shoot, I wouldn't mess with him, and I don't even live there!
Claus
09-03-1999 08:24:10
Maybe there is a problem with the Govenor Balls. Could have flat spots on them... He he...
Claus
Stever(OH)
09-03-1999 05:15:43
My 8n is the same way. I just live with it, as I still get the full range of RPM...
bills (nh)
09-02-1999 18:04:12
Could be your govenor. disconnect the govenor link at the carb and see if idles down. check your linkage for any anomalies. The ford shop manual has govenor rigging instructions.
