2N slugish when running at full throtle
Kurt
02-24-2000 06:36:02
When I have the tractor running at full throtle the engie is sounds rough and is not getting full power, but if I let off the throtle it idles fine. Not sure if there is a problem with the carb, because I just did a rebuild on it last year.
bg
02-24-2000 18:27:37
 Re: 2N slugish when running at full throtle in reply to Kurt , 02-24-2000 06:36:02
Check the timing and centrifugal advance. If the weights are rusted up, the spark will not advance at higher rpm and cause a power loss.
scattcat
02-24-2000 17:38:31
try checking the points gap if you have wear and the gap is to close you can have the same symptoms
raytasch
02-24-2000 06:38:29
Back the large screw on the front of the carb out 1/4 turn. ray
Hank
02-24-2000 14:11:52
 Re: Re: 2N slugish when running at full throtle in reply to raytasch, 02-24-2000 06:38:29
Check to make sure the plugs are clean. If you run too rich they may be fouled. Also check for strong spark in all cyl.
Good luck
