Order Ford 8N Parts Online
1949 8n
bills
08-29-1999 18:01:07
trying to decide wether or not to restore a 49 8n or part it out. The sheet metal is rough, engine needs rebuild (has cracked water jacket), tires & rims junk, hyd works, everythings loose. Does have sherman combo but someone broke the shifter off. My brother gave me the tractor so I have nothing in it, but see that I can throw 2k at it easy. Anyone have any ideas or need parts or have sherman parts (shift lever).
thanks Bill
KCM
08-30-1999 10:44:34
 Re: 1949 8n in reply to bills, 08-29-1999 18:01:07
Depends if you want a work tractor or show tractor. If it's just for work, maybe you can find some used tires and rims and patch the block to get it useable again.
bills (nh)
08-30-1999 12:06:11
 Re: Re: 1949 8n in reply to KCM, 08-30-1999 10:44:34
good point, i think i'll check out the trans and rear end to see what it needs, then decide. just looked at a golden jubilee w/sherman combo, 12 v, and power steering (first i've seen) its not advertised. may make an offer. what do you think its worth, its in good working condition.
micheal
08-30-1999 13:18:23
 Re: Re: Re: 1949 8n in reply to bills (nh), 08-30-1999 12:06:11
just attended an auction with a 2N - stuck, with sherman, and a midmount mower and belt pulley. Sold for $900, that was more than the running G john deere with dual 250 loader! offer him $1500-$2K and part out the N. they use some interchangeable parts. just my .02 worth
micheal
Mac(MI), If you part it out, I could use the tie-rod assembly
08-30-1999 06:59:24
on the right side, as seated.
bills (nh)
08-30-1999 12:08:45
 Re: Re: 1949 8n in reply to Mac(MI), If you part it out, I could use the tie-rod assembly, 08-30-1999 06:59:24
tie rod assy is worn , would need new joints at both ends, but i'd sell it to you
bg
08-29-1999 20:33:26
Unless the tractor has a lot of sentimental value, it would seem to me that parting it out would be the most practical plan. For the $2K you would spend and the money you make from the parts, you could buy a better N. I'd keep the Sherman for my new N, unless someone made you an offer you couldn't refuse...
jon
08-29-1999 18:47:26
Sounds about like my '49..... and I use it all the time!
