Order Ford 8N Parts Online
8N Sherman Trans
Bill H
08-28-1999 11:31:22
I can no longer engage the high position with my Sherman transmission. Lots of Grinding. It use to pop out of gear when the tractor was not under a load. I use to use quite a bit.
What's it going to take to get to it? My guess is it ain't going to easy.
RSP
08-28-1999 13:40:25
 Re: 8N Sherman Trans in reply to Bill H, 08-28-1999 11:31:22
Two problems first you have to split the tractor next when you dissasemble the sherman bearings are the only available parts you can get,one thing that happens is the shift rods where the dentents and balls ride get crudded up and sometimes bend they can be cleaned up and straightened if you have any gear problems like broken or chipped teeth I can hook you up with a shop that can repair the gears Roger
