Order Ford 8N Parts Online
8N Ford tractor transmission
Steve
08-27-1999 18:32:40
A friend of mine has an 8n Ford that seems to be stuck in both 1st and reverse gears. Any suggestions short of seperating the tractor? We have tried to pry it out of gear, but the shifter forks are not budging. HELP PLEASE!
bills
08-29-1999 18:30:05
 Re: 8N Ford tractor transmission in reply to Steve, 08-27-1999 18:32:40
There is a bullitten in the ford service manual under transmission. It mentions a snap ring that must be replaced. This seems to be a recurring problem. I think if you force it you could break gear teeth.
ZANE
08-27-1999 19:26:00
Get one of the back wheels off the ground.Sometimes this is all it takes.If it is in reality in two gears something is not working right such as the lockout detent. It is also possible that one of the shift rail locking dowels has come loose of gotten lost out of the fork.
Steve
08-28-1999 07:10:54
 Re: Re: 8N Ford tractor transmission in reply to ZANE, 08-27-1999 19:26:00
Thanks Zane, we will give it a try.
