Order Ford 8N Parts Online
8N PTO lever kicking out
Gary
08-27-1999 12:05:24
My grandpa has a 8N that he bush hogs with. The PTO engage lever kicks out, and he straps it in place so he can operate. What makes the PTO lever kick out? Can anyone help me help him fix this please?
Thanks, Gary
ZANE
08-27-1999 19:39:27
 Re: 8N PTO lever kicking out in reply to Gary, 08-27-1999 12:05:24
The most common thing that caused the PTO to jump out of gear is that the rear pto bearing retaining snapring has either been knocked out of it's groove at the rear of the housing for the pto bearing or the casting has broken off behind the snap ring.This is usually done bush hogging.Always have plenty of grease on the telescoping part of the pto shaft of the bush hog.This will help prevent it happening.
Another thing that can be wrong is the sliding coupler that engages the front end of the pto ia worn out from being ground into gear too many times.To remove it you must drain the oil from the trans etc and pull the pto and then the sliding coupling through the left side inspection plate under the lift housing.
