Order Ford 8N Parts Online
8N Fuel leaking from carbureter-Help got work to do
Dennis Kern
08-22-1999 13:38:01
When my tractor wouldn't start and I smelled fuel I looked down and fuel was running out of the carbureter at the point where the air clearner tub comes in. The carb is caked with some kinda plastic looking goo too. Anyway any ideas on what is stuck here - and should I plan on a new carb or attempt a look inside?
John
08-22-1999 20:36:13
 Re: 8N Fuel leaking from carbureter-Help got work to do in reply to Dennis Kern, 08-22-1999 13:38:01
I concur with raytasch; I have had that problem too. They are not THAT difficult to re-do. There are some screens (internal) that are probably either corroded out or maybe even removed (!) that are there for exactly that reason.
There is also an excellent video available from our host (YT) about how to do the complete rebuild. As Joe Bob Briggs used to say, "check it out."
JOHN :>)
raytasch
08-22-1999 14:14:31
Shut the gas off at the tank shut off valve and pull the carb. Your problem is most likely a piece of trash under the float valve or a hole in the float allowing it to sink. Carburation on an N is about as simple as it can be. Get some carburator cleaner, pull it apart, and clean it. While you are letting the carb soak in cleaner stop by your friendly NH dealer and pick up a kit and float valve for the carb. Tonight while you are resting you can search the archives and find just about everything you ever wanted to know about N carbs. Good luck, ray
Dennis
08-23-1999 04:57:49
 Re: Re: 8N Fuel leaking from carbureter-Help got work to do in reply to raytasch, 08-22-1999 14:14:31
Thanks...the carb on this tractor is coated on the outside with thick almost plastic looking gunk...suppose that is an indication of what might be happening inside. I am ordering floats and kit today....will take it out and clean it. Thank you for the adivise and help....and THANKS again!
