Order Ford 8N Parts Online
8N Amp gauge
Duane
08-17-1999 14:54:51
I am not sure that my 8N's amp gauge is working. I am assuming that I should see the needle move to discharge when I turn the key on. Right?
It appears to be wired correctly. Thanks for your help.
Dell (WA)
08-17-1999 15:06:41
 Re: 8N Amp gauge in reply to Duane, 08-17-1999 14:54:51
Duane..... ..IF your ignition points are closed when you turn on the ignition switch, you should read about 3 amps. If the points are open, no current (amps) can flow.
If you really want to check your ampmeter, find a 6 volt headlight and temporary run the wire thru the ampmeter loop, the headlight should draw about 5 amps. a stoplight about 3 amps and a tailight about 1 amp.
Realize of course, 8N ampmeters are not a "precision" gauge, but should give you an indication, if working.
Hope this helps..... ...Dell
