Loader hyd pump
Dick in MI 8N41
08-10-1999 14:26:10
I have a dearborn mod 19-22 loader for my N the seal and bearing went (shaft end) the local NHF said there are no parts available for it but he would sell me a new tractor told me to dump the junk does anyone know if parts are available its a vickers vane pump mod 1220 ???
Mike H(MD)
08-11-1999 19:29:08
 Re: loader hyd pump in reply to Dick in MI 8N419609, 08-10-1999 14:26:10
Or you could try NAPA
llamas
08-11-1999 06:29:14
Bearing Service, Schoolcraft Road east (I96 service drive) & Farmington. Haul it in the door, they'll have whatever you need. They actually list some parts cross-referenced to Ford tractor part numbers, although that will likely not work for a Vickers vane pump.
llater,
llamas
Kevin (WA)
08-11-1999 06:10:11
Dick,
I agree with David's comments and would add to take the bearing(s) and seal(s) and maybe even the shaft and housing with you when you go to the bearing house. They can match them up by just measuring them and do not necessarily need to have the number off of them. I do this all the time. The new parts may not look the same as the old ones but as long as the fit the shaft and the housing who cares.
Good luck, Kevin (WA)
David (La)
08-10-1999 14:35:08
Get the number off the bearing and go to the local bearing house, they can replace the bearing and probably seal also. The FNH parts man told me all bearings have a number stamped on the end and you can get another one from the bearing house of your choice. I would try www.timken.com. Good luck
Nolan
08-12-1999 05:43:02
 Re: Re: loader hyd pump in reply to David (La), 08-10-1999 14:35:08
I second this. For several reasons. Price, quality and availability.
Buying directly from a bearing company vs a dealer saves me a bundle every time I do so. The bearing companies also have the parts right there on the shelf. I can go to my dealer and order a bearing for $60 and wait two weeks, or go to the bearing store and get it for $7, and have it in my hand in about two minutes. Such a hard decision!
I also like the quality and selection I can get at a bearing store. As in do I want them sealed or non sealed, shielded? Etc. That's *very* nice! Because I don't always agree with the original decision. Such as Honda's preference for open bearings on their starters. I prefer that to be sealed, thank you very much.
