2n Lift Question
doug(branson mo
08-08-1999 20:46:23
What is the purpose of the spring behind the seat where the top implement attachment attaches? I was putting on chains for brushing hogging (previous posting) and I noticed that I had to be careful not to move it as it would cause my hog to drop. Thanks in advance.
Daniel LYONNET
08-09-1999 00:52:31
 Re: 2n Lift Question in reply to doug(branson mo), 08-08-1999 20:46:23
The spring at the thrd point is a part of the hydraulic draft control.
If you push the control lever down, as soon as the implement is going in the soil (a plow for example) the reaction on the thrd point push the spring, and inside of the hydraulic system close the hydraulic valve to raise a little the implement witch give a levelling effect.
More you put the lever down more the implement go deeper.
That work only with implement witsh work in the soil,.
Regards
Daniel
