Garvas..... .Welcome to the world of "N's" Lift heights.....my 8N arms low is 8" and arms high is 38" for a total vertical movement of 30". 8N's have the standard hydraulic quadrant lift lever on the side. 8N's have a little hydraulic handle under the seat called "position control". Horizontal for "draft control" as in plowing, veritical for "position control" for all other 3-point hydraulic operations including "brush-hogging". If the tractor you are looking at does not have the little lever under the seat and if the tractor does not have a 4-speed tranny, then the tractor is not a 8N. BUT MOST IMPORTANT, wheather or not its an 8N, all N-Tractors (when used to brush hog) NEED an "Over-Running Coupler" on the PTO shaft. The ORC prevents all that energy in the brush-hog swinging blades from feeding back thru the PTO into the transmission, to continue to drive your tractor when you clutch to slowdown for a turn. Prevents such nasties like running into the corner of the barn, fence post, over the bank into the creek, your wifes car, and major transmission expenses. Remember, the N-Tractor was designed before brush-hogs were invented. The ORC is NECESSARY and is not expensive. Yours for safer N-Tractoring, the self-appointed safety preacher (grin)..... ...Dell
