Order Ford 8N Parts Online
6cyl. Ford flat hd. in 8n. with funk conv. kit
Larry In
08-05-1999 22:05:35
Hi folks, am in need of information on where to get parts to rebuild the 6cyl.Ford engine, Comp. is bad on most cyl's. I will have to grind valves and do a major overhaul so may need many parts, any info. would be greatly appreciated. Thanks in advance, this board is the greatest.
JC
08-06-1999 14:34:29
 Re: 6cyl. Ford flat hd. in 8n. with funk conv. kit in reply to Larry In, 08-05-1999 22:05:35
The flathead out of a f400 and up truck was normally used. The 1/2 ton truck or passenger car 6 could be used with a governor adaptor and a carb. base adaptor. Most used the F400 . Rebuild kits are still sold through an outfit on the net.....can't find the link but they are about $380. Use a search engine or check the archives on this board.
bg
08-06-1999 09:11:37
Any good commercial auto parts store(NAPA and others that deal primarily w/repair shops, not shadetrees) should have the parts.You'll need an engine ID, otherwise you'll have a lot of work with micrometers, rulers and patient parts guys. Ford Tractor division didn't make a 6-cylinder for the N. The flathead 6's, V-8's and later overhead cam industrial engines(4 & 6) and v-8's were all out of some other machine.
